1989 Sierra LX project
Started by Mark V8, February 08, 2014, 23:43:52
Mark V8
I'm a grumpy old git - of 46 years with an unnatural interest in old Fords and V8 engines.
This is a condensed version of what I've been up to for the last 3 years or so!
Car bought for the engine
Recipient vehicle
After some nice new wheels
Mark V8
Ford modular T56 from Ebay
T56 modular bellhousing compared to 302 type
Marked up for the chop
Stone cutting wheel on side grinder  :mellow:
Mark V8
Mark V8
Engine going in
Cross member under construction
Gearbox crossmember
Heath Robinson
That should surprise a few people! Good work!
Mark V8
Thanks :blink:
Some engine goodies
Cast steel stroker crank
Forged pistons
Steel rods
Edelbrock performer rpm heads
Intake manifold
Tight fit!
v6gerry
nice fab work going to be a great car makes a change from us V6 boys !
Mark V8
mk22door
But wouldn't sound like a complete BEAST!!!!!!!!!!!!!!!!!
I would love a v8 Sierra, ever since my friend stuck a v8 in his Escort, its always in the back of my mind.
This simply will be the best Sierra ever!
Quote from: Mark V8 on February 09, 2014, 17:39:11
A turbo 24v would be faster!
I guess you will have around 300 to 330 hp and 460 n/m of torque. Best part of it is that most of the torque will be available from 1500 to 5500 rpm.
With those flat top pistons and 60 cc heads you will have 9.1 compression for your engine, you still have room for a turbo. :wacko: :wacko: :wacko:
Mark V8
I was hoping for nearer 10:1  :(
It's going to be 5400cc with the stroker crank, so that should help.
Turbocharging is something I like the idea of but I would need to spend big $$$ on a stronger block!
turboshed
Just a little bit of nitrous for those brown trouser moments
Quote from: Mark V8 on February 09, 2014, 20:49:02
With 5.4l the compression would be around 9.6.
If you want a stronger block go for a 351w. They hold 750 hp with ease.  If you want real big horsepower you will end up, like me, with a dart block. And yes, that is big $$$$$.
Nitrous could be a option, but as I found out, it isn't cheap either if I look at the bills for the broken parts and all the refills.
Mark V8
I'm about as lazy at uploading pics as I am at working on my car  :angel:
Bought some header flanges from the US but they were a bit chunky so I thinned them down and matched them to the gasket
Hydraulic clutch conversion
More to follow!
Mark V8
Mark V8
ARB captive nuts were badly helicoiled, so I made some more
I removed the seat plate, de-rusted it and welded it back on after some weld though primer
Mark V8
Scabby Cosworth front hubs
Some vinegar!
After a few weeks soaking and the odd wire brush session
More wire wheeling...
Mark V8
Mark V8
Some extra strength as I do not have room for a strut brace
Ebay bargain billet 75mm throttle body  :mellow:
Mark V8
New old stock XR4x4 rear spoiler  ;D
New old stock floor bungs
Mark V8
More seam sealer
New old stock rear bumper imported from the states
A load of epoxy mastic
More primer
Epoxy mastic did not give a good finish so I sanded it all down  :-[
Masked up and ready for some more epoxy primer
Old Git at work
Some two pack frozen white
some of it's good and some of it had loads of runs, dry spots and debris!
Not that happy with it so it's all getting sanded again and re-done a small part at a time....
turboshed
Stunning work.alot of time and effort
capri71
Quote from: turboshed on May 16, 2014, 20:05:31
...and vinegar ;D Great work Mark ;)
mk22door
Crikey Heck!
It's sooo good  :2tu:
Amazing amount of efffort and patience.
Cant wait to see the end result. Top job.
Loving the pics. You defo have the skills Mark  :2tu: an absolutely stunning job, way way better than new  :thumbsup:  :thumbsup:  :thumbsup:
