Wheel on Sierra Help
Started by scud, April 11, 2022, 21:00:36
scud
Does anyone know if 7x16 et35 mondeo si wheels fit over cosworth four pot callipers?
Im thinking of changing my wheels as one is slightly buckled and won't balance and the speedo seems out and apparently sixteens are closer
I'm using tsw stealth (very simmilar to the Mondeo ones) 7x15et35 at the moment
Sent from my HTC U11 using Tapatalk
Original the 8x16 are et25 and the 8 x 18 are et15.
But if you use 7x15 et35 at this moment i guess the 7x16 et35 will clear. Only way to make sure is to try them.
scud
Yes it's looking that way, trouble is they're at the other end of the country .
the originaly you mentioned, you mean originally fitted with the four pot calipers?
Quotethe originaly you mentioned, you mean originally fitted with the four pot calipers?
Yes.
You use 7x15 et35 at this moment. The 7x16 et35 has only a 1 inch bigger rim diameter so i don't think that's a problem.
Marc
Which wheels are those, the Escort Cosworth look alikes? Because I thought the Mondeo Si wheels were 16x6.5J and not 7J.
'90 Sapphire Cosworth 4x4
'91 Sapphire 2.9 24v RWD
Mondeo Si wheels are 16 x 6.5. There is a 16x7 version made by Autostar Legend series.
scud
These are 7j I've seen the stamp, special edition apparently
