Capri
Started by Jaanus, March 17, 2025, 01:17:32
Jaanus
Bought this pile of rust last year.
Jaanus
Started on frame rails. 4x10cm box tube
Front
rear
Jaanus
costruction of the inner sills: 3x3 box for top part, 4x4cm angle iron bottom, sheet metal with dimples
Jaanus
First pic shows Boa. well that i sold to get some money back  :laugh:
It also came with a 8.8 & lsd installed
No exact engine plans just yet
capri v8 driver
I love it.
Capri's are getting so rare these days.
That 8.8 axle is a good start. It can handle a ton of power.
Jaanus
The axle and the interior was nice 😅
Lsd was like 1/4 of the price of the car 🤣
Other than that, it's a basic shape of Capri, in the form of rust.
Had a front end accident years ago, and one rear arch and both rear lower corners already replaced (which are rotten now)
capri v8 driver
50 year old cars come with there problems. :laugh:
For my Capri I used a explorer 8.8 as it has 31 splines axles and a stronger LSD.
Jaanus
closing up the gaps
rear chassis leg and spring mount
Jaanus
pedal/brake master mounting and hole for steering cloumn
Inner arches done with repair panels
rear arb mounting
Jaanus
#9
a bit of strengthening, so one could use a regular jack if needed
pieceing together the corners of door opening
capri v8 driver
Making good progress.  :2tu:  :2tu:
Are you keeping the leave springs?
Jaanus
I have thought of 4 link, for now leaves will be fine. plenty of stuff to do and i dont even have an engine/gearbox  ;D
Epoxy primered inside
Sills are on
capri v8 driver
Quote from: Jaanus on Yesterday at 22:08:31I have thought of 4 link, for now leaves will be fine. plenty of stuff to do and i dont even have an engine/gearbox  ;D
I understand. Sheet metal and bodywork is a lot of and time consuming work. In this stage of the work it would be a option to make/incorporate the mountings for a maybe future 4 link system so you don't have to do it when the car is finisht.
I still have leave springs under my Capri v8 and the 20M.
