Ford Taunus TC2 24v bob cossy project in progress
Started by spyros.3, January 10, 2013, 13:25:41
spyros.3
Hi!!i am spyros from greece and this is my tc taunus cossy v6 project with a bob 24v engine in progress.most work have done.the we have to do is to  fix some wires and start up the engine.when the project finish and all is ok....i will send full pictures about all the work that have done.!!!!!! :police:
photo sharing sites
dr knockers
That engine looks very fresh! Im doing the same engine swap to mine, we call them cortina's here!
We're you able to keep the power steering pump in place?
Yeah that engine & gearbox look better than new!  ;D
Going to be a nice one this  :mellow:
spyros.3
this is my first start bob 24v taunus.i upload it in you tube.the project aproach to his end!!!!!!!!   :ph34r:       http://youtu.be/DwvfjC0L0lk
spyros.3
to answer in dr knockers  qustion about the steering pump.........................you must hit a while the inner wing to leave the alternator in place.....................the power steering pump is ok.....no mods need!!!!!!!!!!!!!!! i will tell you more about this project soon!!!!!!!!!!!!!!!
spyros.3
these are some more photos from my project.............this huge 27mm antiroll bar down the diff is from a mercedes but i do not know the model........... :ph34r:
this is a 2300 taunus v6 heavy duty atlas axle.does anybody knows how much power and torgue can accept?? i am thinking to turbine my bob v6
image share...........................
Unless you use the front sway bar from that same Mercedes on the front of the taunus, the rear swaybar make the car very unpredictable to drive in the corners.
dr knockers
Thanks for the info, I'm still a while away from fitting the alternator but a big hammer is never far away.
Loving the build, it is looking very clean in that engine bay. Rear discs as well very nice.
Interesting idea using the Mercedes arb, they say the hyundai stellar ran the same rear end as the cortina and used a thinker arb 18mm iirc. Didn't realise a good front arb match was needed!
Looking forward to your updates on this
spyros.3
the rear antiroll from mercedes, is a straight set up, no mods needed.in  the frond i used a granada mk2 ,2.8 mfi 27-28 mm antiroll bar which is a staight set up too.no mods need too......in taunus tc2!!!!!!!!!!!! the rear calipers are aluminium from a opel astra g !!!!!!!!
Something to read for you:
http://www.houseofthud.com/cartech/swaybars.htm
If you have a 27 mm mm swaybar in the front , you need a 15 to 17 mm in the rear.
spyros.3
thank you very much for the inform!!! i will check it.................. :unsure:
whiteestate
Very interesting reading I'm sure i won't be getting 1 wheel off the ground on my roads though ! but is good to get an idea on how it helps with front to rwd cars to gain more traction great stuff.
spyros.3
I must revise my data................the rear antiroll bar is 24 mm , not 27. a new pic by the way.... :ph34r:
upload foto
whiteestate
Looks hard as nails on those wheels nice work
spyros.3
Azev wheels. I had them on my black capri v8, 7.5 x 16 and 9 x 16.
[attachment=1]
spyros.3
yes indeed!! azev are nice classic wheels with many choises in offset and stag.i had read about your capri v8 in a retroford magazine.mine  are 7,5x17.......i intend to place two 8,5 or 9x17 for rear........cause the rear axle have sortened 1,5 cm each side............. :ph34r:
