Sierra 3d Ecoboost
Started by Jaanus, March 11, 2022, 19:49:04
Sierra's are getting rare now.
Jaanus
Sold the mk1, had no plans for it, no need to keep it :)
Went to the MOT with the mk2, got told its rusted and needs repairs(sills kave koles in it)
Well, i knew it tbh, but i haven't bothered with it. Now that it is cold outside and in the garage, its time to start working :D
My 20M had much more rust but that's where angle grinder and a welder is for.
 :2tu: Top job.
Jaanus
driver side floor
rear floor
Looks like your almost done welding.
Jaanus
More to do are to sort out the sills(inner and outer), rear arches and should take rear axle out and have a closer look at rear subframe and repair if needed
Jaanus
passenger side rear subframe
rear beam mount bolted to the floor and also welded couple pieces so it stays at its place
5x10cm box 3mmm thick
cleaning up to do under the seat mounts
Jaanus
Quote from: capri v8 driver on December 30, 2022, 09:18:42 Almost finisht welding  :2tu:
Repair one piece, finds 2 more places to repair :D
Quote from: Jaanus on December 30, 2022, 14:46:13 Repair one piece, finds 2 more places to repair :D
I know the frustration about rust repair. A small place of rust mostly turns into a much bigger spot or you find a lot more rust that needs to be repaired.
Whit the 20M what started as a simple sill repair turned into a very big job as you could see in my topic about the 20M.
Jaanus
Quote from: capri v8 driver on December 31, 2022, 09:07:44
yep, thats how it goes ;D
front seat mounts and seat/prop mounts cleaned, few crusty bits patched
rear seatbelt mounts cleaned and floor patched and rear seatback mount also new
looks liks all panel joints are rusty inbetween panels and need to be cut out :-
Cleaning is the most work.
I found after 3 years of searching a Original near rust free hood for the 20M. Sadly with the factory synthetic paint.
I already spend 4 days just stripping and cleaning the inside of the hood to bare metal. Forget about modern paint strippers as they don't work so great. Looks like it doesn't work at all with synthetic or 2k paint. i resorted to the good old angle grinder with a wire wheel and stripping disk and 2 days of some elbow grease just to get the inside clean. Now the outside............
Jaanus
took off the brackets for the fuel tank and rear tow hook
spare wheel well floor cut out
cut open part of the boot floor, need to cut more, to access the beam where diff mount to. that beams mounting flanges need repairs.
Jaanus
cut a bit more out of the floor
here you can see the shock tower not being attached to the upper part of the rail and floor. only sealant used in the gap
shock tower only connected to the bottom of the rail
and then i thought, well might aswell take the whole floor out ;D
Starts to get more  rust then we thought off.
It could be worse. This morning i took my 20m for a drive and both the mountings of the stabilisator sheared of the chassis while going over a speed bump. With some straps to hold the suspension in place i made it to my friends house.
First inspection the mounts are rusted from the inside. The speed bump made sure the mounts broke. So i have some cutting and welding to do.
Jaanus
Quote from: capri v8 driver on January 03, 2023, 12:53:32 It could be worse. This morning i took my 20m for a drive and both the mountings of the stabilisator sheared of the chassis
Oof, thats rough :'( . You're lucky that happened at low speed.
I went over my stabiliser mounts. When i unbolted it, one nut came loose and one bolt had previously been snapped and then drilled and tapped. I replaced that nut and welded others, so that they wont come loose again.
Quote from: capri v8 driver on January 03, 2023, 12:53:32 First inspection the mounts are rusted from the inside. The speed bump made sure the mounts broke.
Quote from: Jaanus on January 03, 2023, 19:58:42 When i unbolted it, one nut came loose and one bolt had previously been snapped and then drilled and tapped.
The second inspection revealed that it was the nuts inside the mounts where pulled true the metal of the mounts. These nuts where square 10 mm OD nuts together with 50+ years 2mm old steal this was a metal Fatigue failure.
Still its a scary thought if this would have happend on the motorway at speed as there is nothing else to keep the front end in place as these mounts or bolds break.
Jaanus
Slowly making some progress
All that sheet metal. ;D  Reminds me that i also still have some sheet metal work to do and I'm not looking forward to it.  :laugh:
Jaanus
Quote from: capri v8 driver on January 09, 2023, 12:42:01 All that sheet metal. ;D  Reminds me that i also still have some sheet metal work to do and I'm not looking forward to it.  :laugh:
gotta put some structure back, after i've cut so much out  :laugh:
so, gonna ditch the spare wheel  :laugh:
made new fuel tank straps, 1,5mm stainless. originally has 1 strap and 2 bolts.
need to make an extra brace in the middle of the floor for some rigidity and possibly make a bracket orsmth where the orig. fuel tank bolt holes are
Jaanus
floor panel
welded in
Jaanus
When i saw the first picture with the inner rocker it brought me right back to the 20M rusted out double 3mm rockers.
It looks like you have a a full body restauration on your hands.
Jaanus
As i said, pretty much all the double/triple layered joint has rust between the layers :laugh:
Outer skin welded on
Quote from: Jaanus on January 17, 2023, 22:07:25 As i said, pretty much all the double/triple layered joint has rust between the layers :laugh:
Always difficult to protect it from rust. It looks like you are making big steps now.
Jaanus
slow progress..
both sides had a nut loose inside (rear beam brackets bolt to there)
mounting place for fuel pump and filter
arches are also done
epoxy primered underside
made a strut brace and ran out of paint ;D
Jaanus
an update after some time :laugh:
steering column bearing fitted:
inside and underside painted
and some stonechip protection
and off to paint:
Jaanus
few weeks later got the car back
engine finished too at the same time
and now to try make everything fit together ;D
utilizing some cheap rear beam bushes for engine mounts
main clearance issue. no after pics but ended up grinding the ribs down, heating the intake to mold a better shape, ended up heating and molding the brake reservoir more
Jaanus
intercooler piping angles were horrible. engine is pretty much solid thanks to those new bushes so that short coupler at throttle shouldn't be an issue
flipped rad hoses for less piping
