My 4i
Started by daz4i, August 26, 2006, 21:01:10
daz4i
Thought i would start on me 4i today. Hers some pics to show ya what i managed to get done.
looks like somebody already been here.
and i found this in the boot
i am pleased with what i have found today was expecting alot worse.
glyn
Daz thems all the usual holes m8. I cut an extra hole above fuel sender when i had tank down in case..glyn
daz4i
yeah i thought these would be the norm area for rust, only found that one hole tho, the one in the boot, cant wait for my next day off now so i can crack on.
glyn
#3
once u start its a bug looks a nice prodject I NEARLY FINISHED MY BODYWORK A BIT TO DO UNDER THE BONNET WHEN Engine comes out doing fair bit of work on the 24v eng.are u keeping 12 valve in as they go like stinck as they are..good luck glyn..dont forget when u weld inside scrape the old underseal off from the underside as it will choke u
daz4i
I plan to also turn to the darkside and go the 24v route, i am allowing myself along time to complete the project due to a few reasons. Such as i aint never done nothing like this before, need to buy equipment and such as i go along and other things that take up time and money so as house and family.
glyn
yes m8 you can get carried away with it surprising what thins cost its better to learn as u go along and not rush it good luck anyway Ill keep an eye on yours as its similar to mine glyn
That dont look to bad at all Dale, White 4i's RULE
daz4i
They sure do mate. Will take the kit off on me next day off.
daz4i
Today i have taken off the rear bumper, not to bad there is a bit of rot but it could be alot worse. I then took off the petrol tank as it was leaking, didnt want to see 30 quids worth of optimax get washed away by the rain. Thats all i could be bothered to do today as i got hacked off with the rain. Will post pics as soon as i take some.
daz4i
Well i managed to get some more done today
The front end was in good condition.
Front passanger side arch has some rot.
The rest of that side was all ok, apart from the sill
oh and some here but nothing major
The rear which wasnt bad at all
Drivers side
where the tank used to live
seems i have deleted one as i took one of where the hole was that needs to be plated up. All in all i am pleased with what i found.
