3i project
Started by Taps, December 04, 2005, 18:52:23
Copied from old BB
sjwagstaff
Settled in Member
Registered: Nov 2005  Posted 14th November 2005 12:10   IP
my xr3i project
http://www.interford.co.uk/forums/s...6172#post516172]http://www.interford.co.uk/forums/s...6172#post516172
sorry for the link .
email........... sjwagstaff@interford.co.uk
spanner
Settled in Member
Registered: Nov 2005  Posted 14th November 2005 12:19   IP
Usuall place for holes I see  thought the garage would have told you about that when they looked it over.
sjwagstaff
Settled in Member
Registered: Nov 2005  Posted 14th November 2005 14:36   IP
they were supposed to have ,although holes didnt appear till i had a good prod about , you know a good welder ??
spanner
Settled in Member
Registered: Nov 2005  Posted 14th November 2005 16:59   IP
yep  bit of a treck up here for ya though
sjwagstaff
Settled in Member
Registered: Nov 2005  Posted 14th November 2005 19:44   IP
aye , even taps is a bit too far ,
doglegsxr
Settled in Member
Registered: Nov 2005  Posted 15th November 2005 12:23   IP
i'm good with a heat gun
spanner
Settled in Member
Registered: Nov 2005  Posted 15th November 2005 12:32   IP
He's just had a respray Andy, not sure he wants a bare metal shell
doglegsxr
Settled in Member
Registered: Nov 2005  Posted 15th November 2005 12:33   IP
it'll get rid of that sound deading stuff thats for sure
spanner
Settled in Member
Registered: Nov 2005  Posted 15th November 2005 12:41   IP
Aye but a roof linings a bugga of a job!
Make sure ya spray that floor with waxoyl before ya lay carpet again steve  try and preserve it for a few years.
sjwagstaff
Settled in Member
Registered: Nov 2005  Posted 15th November 2005 13:20   IP
gonna paint floor with hammerite when all welding sorted out. ,do i replace sound deadening or not?
or just put carpet back on its own?
spanner
Settled in Member
Registered: Nov 2005  Posted 15th November 2005 17:06   IP
Better with it steve. Make sure it's dried out though.
sjwagstaff
Settled in Member
Registered: Nov 2005  Posted 15th November 2005 17:20   IP
will have to get new ,other stuff was bit rotten.
spanner
Settled in Member
Registered: Nov 2005  Posted 15th November 2005 17:26   IP
Bit of house carpet underfelt would do steve. Just deadens noise a bit and gives you a bit of a soft comfort feel for yer tired old feet
Administrator
Registered: Nov 2005  Posted 15th November 2005 19:03   IP
Quote:
Do ya drive in ya slippers  , bin it and just have the carpet, its cos of that holding water like a sponge ya floors rotton
spanner
Settled in Member
Registered: Nov 2005  Posted 15th November 2005 21:15   IP
No they let water in
Ditch carpet aswell then steve since it holds water too  ya just have to go the lotus way and have nowt
maddoldbugger
Administrator
Registered: Nov 2005  Posted 15th November 2005 21:44   IP
and whats wrong with that,, i dont see any carpets in the picture on ya siggy! come to that i dont see a roof ether
spanner
Settled in Member
Registered: Nov 2005  Posted 15th November 2005 23:20   IP
Nothing wrong with it at all Tony  just the way I like it  wouldn't have it any other way, I hate hoovering
NorwayNick
Newbie Member
Registered: Nov 2005  Posted 16th November 2005 06:20   IP
need to fit under floor heating in the car steve, that will dry out the carpet He...he
sjwagstaff
Settled in Member
Registered: Nov 2005  Posted 16th November 2005 08:19   IP
well its quite well vented at the moment
sjwagstaff
Settled in Member
Registered: Nov 2005  Posted 25th November 2005 13:22   IP
all welding now done and boot area just about finished,putting some dynamat stuff down before the carpet goes in.
doglegsxr
Settled in Member
Registered: Nov 2005  Posted 30th November 2005 13:47   IP
-New post-
what did you use in the boot steve ? looks good
sjwagstaff
Settled in Member
Registered: Nov 2005  Posted 30th November 2005 15:46   IP
-New post-
smooth hammerite Andy .
took battery out and had a prod and now need new battery tray etc welding in ,fuse box side looking at next as still getting a puddle.
doglegsxr
Settled in Member
Registered: Nov 2005  Posted 1st December 2005 09:22   IP
-New post-
had the same trouble with my grey one git big hole under the battery tray in the bulk head, i tried useing a bit of sealer round the bottom of the fuse box but it's hard to get at and messy but it worked
sjwag
cheers for copying across Rob.
took fusebox out as far as it would go today and all is fine underneath ,so can only assume water is coming in through windscreen seal.will keep searching till i get there
sjwag
battery tray area now  sorted,so think i shall take dash board out to find leak on the drivers side.
does dash come out easily ?hope it does
daz4i
Mine used to leak on the drivers side aswell, hope you get it sorted out soon mate
sjwag
right steering wheel is off ,clocks out and dash is ready to be taken out ,will do that tomorrow hopefully if weather is ok.then to sort where leak is coming from.
sjwag
right dash is out and leak looks like its coming from below corner of windscreen,about 3"down.there is a bit of rust on A pillar bit so must be about there somewhere ,possibly coming in from where wing joins,still awkward to get in properly.
have dried out fotwell area so just see what happens next rainstorm.
rallyslag
looking a lot better now
sjwag
cheers,be better whan black goes on and windscreen back in .........
xr4man
looks real good, hope i don't run into anything like that with my merk
sjwag
well all painted now,ready for screen to go back in.
sjwag
battery tray area now painted up and floor done.
next job will be sound proofing stuff.
Looking good Steve soon be finished
