The latest saff project
Started by Owain, February 03, 2007, 19:09:37
  will start to strip it fairly soon now that i can pull it out the corner and push it back with ease.
fatboy billy
slacker why isnt it in already lol
will make the e tho o only thing it was lacking was a decent engine
Quote from: fatboy billy
it's because im lazy and whilst the e still works, im in no real rush, washed it and hammered my front arch back in today
The 2.9 12v is very underrated.
DOHC advocates are just blind  I hate the f....ing things.
Get it slaped in, but paint it up first...
Quote from: TwinTurbo
i hate the tincans as well rob, need to pull the v6 apart first, make a few adjustments etc, clean up and polish a few bits maybe before it all goes in, as might as well play with it whilst it's out, makes sence like, but needs cash
Ovalracer
I've just moved over to driving a 2.9 XR4x4 after my Sapph 4x4 twinky got wrecked, and the difference is unbelievable. Only been out in it a couple of times since I bought it a week ago, but loving it already.
I think you're saff is one of the nicest I've seen, so will be even better with the 2.9.
You going 4WD or sticking to RWD ?
it's staying rwd, picking my gearbox up off barry at xr4isparescentre this weekend coming, along with an assortment of other spares etc for the conversion
2 saffs
Good to see the stand earning its keep already LOL
mark
#9
are you getting mr taps to do sum head work
hes good at getting power out of 12V's
or this would push it along well  http://www.xrstyle.co.uk/forums/viewtopic.php?p=177546#177546]http://www.xrstyle.co.uk/forums/viewtopic....p=177546#177546
Done a little bit before the light faded yesterday
Quote from: Owain
Yes that certainly looks a little bit to me
Tortoise and the Hare rob my friend
Quote from: Owain
Oh ya was playing with ya pets no wonder its so little
Why has it got a 24V sump?
He couldnt afford a full 24V only the sump
Nice!
Good to see another V6 conversion. A proper engine for a proper car (or should that be propah  )
No such thing as a 24v sump as the 24v and the 12v are both based on the same block, right?
Quote from: Remko GT
Wrong
The 12V has 2 things missing
tiff
that'll be very nice when it's finished!
fatboy billy
Inlets off, both heads are off, just inverted the engine to finish cleaning up the sump before a take that off as well ready for a spot of work on that, forgot to charg the camera up the other day, then went up the pub so pics are to follow.
Damocos
More progress on yours than on mine...!!!
Super 12v
#24
has this engine been rebuilt previously? Apart from the block and inlet manifold being painted black there's a few differences I would expect in a stock block. As it has the non cat pistons I would assume its a pre 92engine but it has the extra counter balance on the crank like on a 24v or later 12v's. The alloy fuel rail would imply its post 1990 also and as far as I knew thos pistons were only used up until 92. block also has addition webbing my earlierblock doesnt have. Was this from a late scorpio as it obviously a RWD enge with at pick up.
bit confused as i'm sure the late spec engines shouldnt have those pistons
And it's not too later engineas it has the wrong crank pulley for a frog eye scorpio.
Sorry for rabbiting, just trying to pin point a year of that engine
Rob dont know if this helps but its the engine out of Simons Black 4x4 I put the 24V in.
Super 12v
cheers rob, simons is a K plate isnt it. some of the parts ring true with a late spec XR but some of parts seem to be wrong, the pistons mainly.
Nothing bad, in fact looks like a good basis for a rebuild. I just wouldnt have expect to see many of the parts in  12v til much later than 92 and then it certainly should have those pistons  unless ford have really raided the parts bin i'd say thats rebuilt previously.
Rob
Quote from: Super 12v
Rob
Its on a J plate so think your right Rob its been rebuilt at some time.
All Simon said was that it had covered 160K miles and needed a crank seal, just seemed a shame not to pull it apart and play with it whilst it's out the bay
ROB S
Owain, wondered where you'd been mate. Good to see the lovely Saph again, it will be amazing with a 2.9 in it. Good luck with it, i'll read this with real interest.
Rob
