Popuptoaster Project Cortina
Started by Taps, May 18, 2007, 18:54:44
Martyns Scorp Manual 24V Cosworth
mark
popuptoaster
Is that an original manaul or a cut'n'shut
popuptoaster
dunno, was in it when i got it.
bortaf
Mmmm cortina and 24V, a bit like styrawberrys and cream (no not nice at wimbledon) i mean go together well
russ-2.9
gotta love the old cortina, built like tanks (me old man had 3 of em  ) You still gunna get your TS ready for fordfair Rob? or is back burner time again for the old girl?
Right donar engine, running when removed.
Sump removed and pan checked, in the bottom were small bits of a guide
Fine silvering of the oil.
Tensioner Blade bottom end checked, slipper still in place but it had slipped in the location slot.
Oil pick up checked slither of metal in it
Oil pump removed stripped and checked, top plate scored, pump body 2 deep scores
So strip out front of engine
Timing cover removed
Blade removed
So that explains the gudie bits, the silvering of the oil in the bottom of the sump and the metal found in the oil pick up and the scores in the oil pump.
popuptoaster
its frightning the amount of these engines that seem to run fine but have this problem. still, tough as old boots otherwise (i hope) :D
Final'ly got all the bits needed to put the engine back together
New blades fitted.
New front crankshaft oil seal fitted and cover back on
Old tensioner was past it on inspection, piston had been running off of centre and had put a deep groove into the bore which most likely means that the blade had been snapped for a long while, new ones are no longer available so a used one has been fitted.
New oil pump fitted
Sump with all new gaskets and seals fitted
New cam cover gaskets fitted
Front end fitted up
New rear crank oil seal fitted
V6 EDC
Looking good m8, should of done that with mine before i put the lump in, but there you go. Gonna be rude being a 24v tina...
wolfie
I love 'Tinas me!
i miss my mkV..half think 'bout getting another one
Very cool project going on there!!
Well engines in the bay
But things to sort from the start. used the engine mounts from the 2.8 that was in there, Alternator is sitting on the front of the crossmember
Slight mod to the heater matrix box but not as much as I was lead to believe was required
So so mods required
steve
we want more pics
top work as usual taps
Quote from: steve
we want more pics
Should have more by end of next week, still scratching me head on how to get round the alternator sitting on the front cross member.
#16
hello taps,
good work, keep it up.
i did a engine 24v swap in a taunus (cortina) for a friend and i replaced the 24v alternator for a smaller toyota corrola one, and i cut a small piece out off the chassis rail to make room for the steering pump.
but i have also seen that people cut out a piece out off the crossmember, but i don't recomment that.
Quote from: capri v8 driver
hello taps,
Cheers for that Paul, will look for a smaller one, as for cutting the crossmember thats a no no as you say.
Sierra-bloke
Hello Popuptoaster,
I looked over your thread. It is amazing how this blade tensioner is so prone to breaking in alot of cars.
Its looking good thou.
popuptoaster
Taps is doin the hard work not me, but cheers anyway. :D
Right alternator problem, to recap, pulley hits on the crossmember and thats without the engine mounts sitting fully home onto the crossmember.
so few changes have had to be made
From this
to this
Will now be running a Nissan alternator, just got to make up adjuster bar and that bits done.
yay  Nissan parts  (I must hide my NX from you lot  )
Cooling fan now fitted,  Scorpio aircon fan used.
Blank off plate made and fitted
tiff
nice work again Taps...
does Mr Knobbly-knees still do the tensioners and gaskets these days?
Quote from: tiff
Yes m8
SIDIBEAR
Quality work, but then what else could you expect from Rob?
Nice to see it coming along.
tiff
Yes m8
lol you knew who I mean 't then!...
excellent stuff..hats off to your handywork again
Slight problem today when I lifted it on the 2 poster ramp, rear springs fell out
Lowering springs I suspect with the wrong size shocks, something that will need to be addressed later
Right, bulk head cut to take the loom
Strengthening plate welded in.
Alternator mount bushed to take the Nissan small size mounting bolt
and adjuster brackets sorted
steve
popuptoaster
ahhh yeah dont worry them springs, its too low at the back, im gonna bin them anyway and get some more sensible ones in there, they were in it when i got it. I like being able to get a leg on down the lanes so i need some actual suspension rather than have it on the bump stops, it'll probably go back up to standard S height, it may not look as cool but i dont care about that
