Thunder Saloon 24V
Started by Taps, December 02, 2005, 23:17:23
nick
still going steady then rob.
taps mate
your doing such a good job once the other side is done its as near a new shell as ya can get!
its well worth all the effort!
looking dam good
Right thats the bodywork done for that side
I had thought about fitting the kit to this side before starting all again on the rust on the other side but I've now been convinced to get on with killing rust lol
nick
mmm i found there was something strangely enjoyable at poking through rust and removing it.
I couldnt help myself, Honest
No cowboy job there Taps.
Puka job so far, keep it up, I guess your gonna keep her for a while when done. Well worth it.
Yeah once its done Dave its stopping, the 4x4 will come off the road then to sort the V8 4x4 set up out.
nick
v8 4x4? is there anything you wont try
Off I go again    Passengers side.
Finally got some spare time, todays efforts
Got these off Ebay as well £25 the pair brand new
next youl be making new xr4i shells for e-bay, i think ya done most the parts over time ya just got to do them all in one go!
nick
Quote from: maddoldbugger
he has a point rob, you pretty much have replaced that entire 4i!
Chris
When doing a job like this, i.e. a complete shell rebuild, how much do you think you are strengthening things by just completely welding the panels together versus the spot welds that Ford originally used?
Chris
IBA   15631
Quote from: Chris
Chris
Well, I spot/plug weld where Ford do Chris and seem weld the rest, I dont like seem welded flanges, i mainly cut out and cut panel to fit in rather then weld metal over, I also use thicker metal then what I'm replacing, so, what I've done should be stronger then what I've replaced
Chris
Thanks for that....   Do you ever make outer panels, or are they easy to get hold of....   I need to redo my rear outer wheel arches on my Estate, and the lower part of the tailgate, but obviously, the panels aren't available, will need to find an real body guy (expensive)
Chris
IBA   15631
Quote from: Chris
Chris
Arches are cheep enough over here, tail gate you'd need to make your own, lot of panels are available for them here.
Chris
Well, thanks again
Good luck with the rebuild...   I will be doing some of that over the next few years, no doubt...    But the cosmetic stuff, I will be leaving to a good bodywork guy.
Chris
IBA   15631
Chris if you need panels we could always ship some over m8, when I get 5 min's will scan whats available and post it up for you, is yours a Mk1 or Mk 2
king2
wow
that is a lot of work done on that car
Chris
Hi Taps,
Mine's a Mk2 Ghia Estate.
Thanks
Chris
IBA   15631
Chris
What is the purpose of having the 'holes/slots' in those floor panels?
Chris
IBA   15631
Quote from: Chris
Chris
They are either drain holes for when bodies dipped or crumple zone
MORE LIKE READY MADE RUST HOLES!
Hole where someone run the loom for the 2.9
front foot well all done
Rear foot well
Chris
What kind of welder are you using?  Gas, MIG, TIG or stick?
BTW, I have found a distributor for Hadrian Panels, over here, and I think even though his prices aren't cheap, $100 for a pair of rear arches.....   By the time I pay my own shipping, I imagine it will be about the same price, but it might be worth verifying that.
Chris
IBA   15631
Quote from: Chris
Chris
I use a mig, $100, whats that work out in £'s, can find out price of arches over here.
