mk2 granada 24v
Started by mk2 cossie, January 13, 2010, 13:44:48
mk2 cossie
hopefully some pics of my motor
not mastered PCs yet
*There you go mate, I`ve resized them as well because the were huge  *
Ade
#1
No, you really haven't got the hang of computers yet
Get on to http://www.photobucket.com]www.photobucket.com and follow their instructions
Leebay
#2
Give me a minute mate and I`ll host them on my photobucket account for you and edit your post. If you`ve got any others you want to post email them to me LeeLDSEngineering@hotmail.co.uk
Smart granada    was that a recent track-day at Brands?
mk2 cossie
thank you very much Leebay
very much appreciated
they were taken at the retro cars/retro ford track day at brands on 22/07/2009
was a very good day, even tho i did manage to boil the brakes
Ade
Looks great, got any more pix, under the bonnet etc?
mk2 cossie
i do have some of under bonnet, but i shall get someone who knows how to post pics to actually show me how to post them the correct way and go from there i think
Leebay
Ade
mk2 cossie
thank you very much for posting them for me mr Leebay, much appreciated
thanks for the comment Ade
needs a good polishing up really, as the road salt is getting to everything
Leebay
Not a problem mate.
Just noticed the polished chrome plug plates. You make them? Or did they come with the rocker covers?
I`ve lost both of my plastic ones grr, probably at the bottom of a box in the workshop somewhere.
bitterend
who made up your manifolds?
mk2 cossie
leebay- the plug covers i made from a sheet of aluminium, same as the surround for the air filter, although i got some one to use a circular saw to get the plug covers cut to just the right width
bitterend- the manifolds were made by Powerspeed who at the time were in hothfield, but have recently moved into ashford. not sure if they made much difference to power, but they made a huge difference to how smooth the car goes between 3-4000rpm
smashed
class car mate love them granadas and im hopeing to get the same done with my manifolds all goin well.
limey
mk2 cossie
Well, it's been a long sleep for this thread, so I'll bung a couple of pics in of the ole girl ;)
And this polishing lark becomes almost a weekly chore through the winter  :rolleyes:
And hopefully a vid link to the dyno run
https://www.youtube.com/watch?v=uQtdC_TbvyA
capri71
Quote from: mk2 cossie on March 12, 2010, 00:04:15
Don't think they will with the standard intake - thats the bottleneck imo. Nice car, i love Granadas :thumbsup:
v6gerry
Quote from: mk2 cossie on May 10, 2014, 01:07:16
Nice to see it again you don't see any on the road these days !!, yes p/speed moved to ashford they are up on henwood ind est ,
Lemon-Ade
Cracking car mate , I hadn't seen this thread and it sounds great on the rollers  :2tu:
mk2 cossie
Quote from: capri71 on May 10, 2014, 12:03:36
That may be, but my bum dyno reported that it was definately smoother through the revs  ;D
Cerainly less 'cammy' anyway  :thumbsup:
As for the inlet manifold, I have a spare that has been hacked up and in the process of being modded at the mo  :mellow:
mk2 cossie
Quote from: Lemon-Ade on May 11, 2014, 11:04:08
Thanks Ade  ;D    Was only a 2nd gear run up to 6k as thats what the standard ECU would allow. Can get full throttle loads above 2k now with the Emerald switching the 2 autobox solenoids when necessary  :mellow:
capri71
Quote from: mk2 cossie on May 12, 2014, 18:40:13
Interesting. What are you doing to it exactly?
Heath Robinson
mk2 cossie
Not much to report on the inlet manifold front other than a pic of the spare plenum with the end caps off and the face machined flat
Got some new end caps welded up and awaiting milling to bolt them on
v6gerry
looking good how much are you extending the cap by , be interesting to see the differants it makes , did you manage to get the inside cleaned right out ?
when are you hoping to have it back on car .
mk2 cossie
Quote from: v6gerry on September 06, 2014, 11:03:31
It is a bit of 3inch pipe that has been cut in half, with a flange for each side welded on to. So hopefully it will be a decent amount of clearance compared to the standard glued on covers  ;D
Hopefully I can give the intake ports a bit of a tickle, as I have some flap wheels on a long shaft to get in there with. Will only give the casting a tidy up, not going too mad there.
Hoping to get it finished off and fitted in a couple of weeks time, shall post the findings up on here as soon as I know though  :mellow:
v6gerry
that should make a big different be interesting to see,  be better with a turbo set up as to force the air through !!! my engine is nearly done waiting for head gaskets to be made he thought he had them in stock but were for 93.5  bore mines 94 , been a long wait !
mk2 cossie
Well, hopefully some monies will have swapped hands and I'll have some pics to post up of my modded inlet manifold by the weekend  ;D
mk2 cossie
Bit later than the weekend before last, but a few pics of my manifold before I've set to it with the polishing equipment  :-X
v6gerry
Hi paul that looks very nice and should make a lot of differants  nice bit of tig welding there  :thumbsup:
mine is on its way now got the head gaskets should be on the dyno very shortly  ;D
mk2 cossie
Thanks Gerry  ;D
Yeah, the lads at Specialised Welding have made a lovely job of it.
Taken a back burner for the mo tho, as one of the front coilovers snapped last Friday  :rolleyes:
