Belgian Cossie Capri
Started by KetsMcLets, December 26, 2018, 23:38:57
KetsMcLets
Hi all!!
I'm Thomas from Belgium and would like to introduce to you guys my Capri, as it's nearing it's completion. Only needs to be painted now but I have another project so it'll have to wait a bit. Anyway I've grown to like the matt black colour so not in a hurry.   The final color will be a sort of signal green..
It started life as a 1.6 MKIII that my dad and me bought in 1999, partially disassembled and then just sat there for 16/17 years lol..due to always other project cars and stuff.  Then I said enough is enough and started restauring it but most of the parts were lost or rotten away because of bad storage. So it really is a sort of Frankenstein car with parts from all over. So don't have to worry about pescy things like originality and stuff.
I had first put in a 2.0 injection pinto engine but got tired of that pretty quickly, that's now in an MK1 Escort from a friend. So the previous winter I spent installing a Cosworth BOB engine and ZF axle and ran it on a BOA ecu (thanks Paul) for a while but this summer I got a Megasquirt-type ECU and had it mapped properly recently.
I will make a spec list of all the things changed on the car, been wanting to do a summary somewhere for some while. It's also good for future reference ;)
Engine:
- Ford Scorpio MKII BOB Cosworth, very clean and with just 100.000km
- standard Pinto subframe with 2.3 engine mounts w custom rubbers, engine sits 3mm above subframe now
- Efignition standalone ECU with all new custom wiring loom and plugs.
- Launch control with 1 meter flames for those that drive too close or just to scare pedestrians and cyclo-terrorists
- no power steering
- aluminum radiator 70mm with electric fan (gonna upgrade to a more powerfull fan soon)
Gearbox:
- 2.5TD MT75 diesel gearbox with long 5th
- V6 bellhousing
- 2.8i flywheel
- LUK clutch
- custom gearbox mount
- all new bearings and fully checked and assembled by a professional transmission company
prop shaft:
- Escort MKII 1600 sport shaft with integrated slide-piece
- MT75 front end welded on with the rubber donut
- custom mounted
Rear axle:
- MKI 2.6 50" rear axle
- ZF 4-plate hardcore motorsport differential  :mellow:
- 3.75 MKIII 1.6 crownwheel and pinion
- MKIII stabilizer supports welded on
- Blasted and powdercoated
- Disc conversion
- all new bearings, diff was fully rebuilt with plates of a Porsche of some kind and the axle was then put together by the same company that did the gearbox.
brakes:
- Ford Scorpio Cosworth MKI calipers all-round, rebuilt
- Ford Focus ST170 front discs 300mm
- hubs machined
- custom caliper adapters
- Ford Scorpio MKII rear discs 256mm
- stainless lines made to order
- Ford *** handbrake cable (don't remember what it was from), extra bracket made to fit
- standard pads but going to Hawk or Ferodo DS2500 when they eventually wear out
- Landrover master cilinder
- brake servo from Ebay.com, don't know the make but it had the right pcd's for the bracket and BMC
- custom servo brackets to dodge the engine covers
suspension:
- Burton springs on original dampers up front
- Hi-jackers on the back
- 2.8i single leaf springs
- full black polyurethane bushing set
Wheels:
- Image magnesium 7.5x16 fronts ET unsure
- Image magnesium 8,5x16 rears ET also unsure but it's low
Interior
- Ford sport steering wheel
- sport seats on Capri rails
- Black dash and door cards from an MKII
- black leather roof lining
- black carpet
- "Capri" floormats
- V6 dials with wideband gauge built-in, water/oil temp gauges soon to follow
- USB radio
Other modification:
- custom bumpers, much smaller than stock
- MKII grill with the Cosworth emblem inbedded
- window louvres all-round
- battery is in the boot
that's all I remember by heart, will add if I think of something
[attachment id=1 msg=82345]
[attachment id=2 msg=82345]
[attachment id=3 msg=82345]
[attachment id=4 msg=82345]
[attachment id=5 msg=82345]
[attachment id=6 msg=82345]
[attachment id=7 msg=82345]
[attachment id=8 msg=82345]
[attachment id=9 msg=82345]
Belgium Bastards
KetsMcLets
#1
a movie from when we were dyno'ing it the other day, battery went flat so no movie of the last runs lol
Belgium Bastards
Zackspeed280
Looks great, any chance you've got a photo of your gearbox mount as that's the next thing I need to make for mine!
Westfield (R ) 2000 Zetec Sport - awesome, always seeking lightenment!
Range Rover Sport Overfinch Tow Car
Capri 280 (E) 24V Supercharged in build
KetsMcLets
I don't think so, but I'll have a look when I have some time
Belgium Bastards
