Simons 24V Project
Started by Taps, September 17, 2006, 17:56:57
From 12V
glyn
#1
From 12V
is it sick Taps m8?
Quote from: glyn
is it sick Taps m8?
The 2.9 12V aint sick as far as I know Glyn    he just fancys that 24V in its place.
does this mean "simes" is going to make his 2nd post?
he he he he
simes
Quote from: maddoldbugger
he he he he
It might do
Quote from: glyn
is it sick Taps m8?
No its not sick at all. But it does leak oil by the bucket full.
Simon
victim
It's supposed to, it's a sierra!
12V's out
He also needs new front springs
One with spring broke top and bottom
and the other boken on at the bottom
william
hello
Nice car! i've got a xr4x4 too.  keep us posted with the progress!
regards,
william
glyn
#8
12V's out
I can see why u used 3 jacks i only got one at om...glyn
do remember to cut this pipe off
[attachmentid=994]
with this as it is, ya knacker the cam cover gasget and its a right bugger to get the cover off!!
also leave the cooler and extension on,, just loosen and spin out the way
[attachmentid=995]
once the 4x4 sump and diff is fitted this will all fit back on but will need to be angled back around 30 degrees.
going well chaps!!
ya can tell taps is well off,, 3 jacks?
i make do with one and piles of bricks
[attachment deleted by admin]
glyn
#10
[attachmentid=994]
[attachmentid=995]
going well chaps!!
tony yea tony it was the blocks on the jack that gave way ,didnt fall far though..glyn
Super 12v
Nice one simon, coming along then
could i just refer you to this post of mine as I spotted something on the 12v that came out  can swap for the earlier 12v setup if need be.
http://www.fordpower-uk.co.uk/index.php?s=&showtopic=1518&view=findpost&p=9551]http://www.fordpower-uk.co.uk/index.php?s=...post&p=9551
Quote from: Super 12v
Rob, if his not replied by tomorrow night I'll tell him you want them as his coming up the Garage, dont think he will need to swop for others as the 24V ones will fit.
simes
Yes you can have them. As taps says the 24V setup is different.
Simon
Super 12v
Quote from: simes
Simon
Cool, well i wasnt sure if the engine had another home or not, but that would be brilliant. The early setup interfers and limits my oil cooler sandwich plate fitment. so it'll help alot with the new engine install
Many Thanks
Rob
Well ya could say todays been a 1 step forward 2 steps back .
Having took the 12V sump off to get the Oil pick up pipe for the 24V
I had hoped the timing cover would come off without removing the heads but despite removing all the bolts its stuck somewhere a the top of the V and will not come off.
Well I thought it might have been stuck on a dowl but no, Ford hide a bolt in the V that ya cant see with the thermostat housing bolted on
His knackered tensioner arm
rob
its normal for the N/S head/camcover to be messy like that,
remember, that one vents to the plenum and does get reverse pressure flow, they aint the best valves!!
the N/S vents to the air filter and never gets a return pressure
ow and thats the twin fuse box loom isnt it?.. ya can dump 99% of it tho
rob
Would that explain why the o/s head is so clean compared to the n/s as well Tony.
rob, yeah, it seems the norm
daz4i
This is looking good, keep up the good work chaps. Then once you finished you can come and start on mine
Beastmaster
yeah ,all the cam covers look like that,had me going at first, oh and you gotta love that sneaky little bolt up the back of beyond. speak to barry at4i as he has new h/d blade tensioners, be worth replacing all the chain guides as you got it in bits, check out e-bay as theres a guy on there doing complete gasket sets for about £70.00 unless you know better...if so let me know
The new Tensioner arm supplied by Barry XR4i spares is on
Timing covers back on
Water pump, front pulley and Crankshaft sensors all back on, got to get a new Crank pulley bolt, god knows why they use a stretch bolt for that.
Well after a very long Day Simes and I have got his car to this stage
simes
#24
Some more pictures now my photobucket account is working.
Timing cover and water pump backon as are the rocker covers plenem sump and diff
Flywheel on
More side shots
If you want to keep the paint on your rocker covers, don't steam clean them. Another job for later.
simes
#25
Old engine and new engine
now mounted on the cross member
Choice of alternator
They are identical, both 90 Amp
But only one has the right pully
All the bits bolted on. BIG aint it.
simes
#26
Right now in the engine bay before fitting the engine.
The EDIS 6 module
The dreaded EGR stuff.
Yes I know it's not quite straight
The vacuum pump for the cruise control behined the headligt.
Don't drill a hole in the washer bottle like I did.
Now the mounting point for the Air filter box
This bracket bolts straight into the holes that bolted the old box into. No drilling or measuring required.
The air box
This fits perfectly but you have to cut the lug off. I was going to cut a hole in the wing but decided it would be easier to bolt the lug to the wing and cut a hole in the box. Still to be decided.
Now back to the engine
Gearbox on, I'm missing pictures here Taps, so back of engine only
And the heat shield for the starter motor wires.
And engine in
Now the dreaded wiring loom
Lots isn't there.
Bit it splits into
The engine loom, the bit we want
the ABS loom
Everything else
Damocos
I take it the aircon will still work ok with the 24v ecu & wiring?
simes
The aircon wiring is part of the engine management loom for some reason. So I am keeping my 12V loom in place.
If you do that then you only need to connect two wires from the 24V ecu to the 12V loom then the air con will still work. (unplug the 12V ECU first though)
In my 24V loom I also pick up the VSS, KAM and Fuel pump relay connections from the 12V loom as well.
After that it's just two power connections and a couple of ground wires.
simon
and the brown/white for the temp, green for the rev counter
