Rust Has anybody ever used Owatrol C.I.P
Started by Ml Craddock, October 26, 2022, 11:38:50
Ml Craddock
I have a slight rust problem round the 2 front headlights on a mk 1 73 facelift capri  hope to get the area sand blasted and then treat with Owatrol C.I P  has anybody ever used it Michael
The rust comes from the inside so if you sand blast the fender you need to do the inside as well.
To get good excess you need to remove the head light bucked plate, just a few spot wells.
Then do the repair and use expo primer before putting any coating on there. Owatrol C.I P is mainly used for ships.
Ml Craddock
Thanks paul I was away for a while so I was not on this site ML
