Twinky driven to destruction
Started by Neil, August 21, 2006, 23:26:36
Neil
check out video clip from Golspie sprint, listen to engine and tyres squealling their brains out
the net day i blew up the headgasket and turbo     andf trailered home
9.2 meg worth
http://s60.photobucket.com/albums/h29/TerzoNeil/?action=view&current=golspie1.flv]http://s60.photobucket.com/albums/h29/Terz...nt=golspie1.flv
242 bhp at 13 psi of boost
Phatphil
Sorry to hear that m8, hope you can get it sorted soon. That sprint looks good fun, I will have to put up some in-car video from the sprints we do.
Phil
Neil
that happened in June
it's all repaired now check new set up with a stage 2 T3 turbo, that was done running a T25 turbo at 14psi, now running 19psi
Now you can go backwards quicker
Mikey J
You can tell it was 2wd, check out the oversteer.  Also, the engine always sounds as if the induction is very free flowing.  Have you ported the heads Neil?
Mike.
Neil
Mike J
yes it has all 8 ports done
oh BTW it's 4wd not 2wd
Mikey J
Quote from: Neil
Mike J
Neil,  I know it's 4wd now but when you spun off it was 2wd, hence the oversteer and tyre squealing
Mike.
Neil
all the video clips are 4wd, it was convert this season for better results
Neil
this how hard i was pushing the car at golspie as seen in the video clip, mahaged to get it on 3 WHEELS with stiff coil over suspension
